Creeping Death issues update
[8D] Well I finally got my Creeping Death Turret recoil to work decently. I sprayed the silicone lube to the barrel and that helped a lot. It still seems to jam up though. The barrel sleeve is epoxied to the brass sleeves that recoil and I tried to slip it off and twist it and it won't come loose so that's good. I also tried prior to this to center the brass recoil unit but would not center at all. It's way off so I think that's why it's jamming up. I have to spray a liberate amount of the silicone lubrant to keep the recoil moving smoothly prior to firing. The firing mechanism however works flawlessly as I loaded up the magazine and filled the commmanders cupola. It fired every round without missing a shot. I dont' think I can do anymore to the recoil other than taking it out completly so I am content to leaving as is for now till I can stomach tackling that issue. Overall though I am pleased with the Turret.
Thanks for the suggestions guys.
ON, CANADA
Can you tell me what type of inner barrel they use. Is it something that can be replaced with something with a tighter bore. I was thinking of getting one and trying to upgrade it.
Have you talked to them about the gun being off center? They seem to want their stuff to take off; so, I would think that they'd want to make it right.
