ORIGINAL: GarySS
WiLL-3D -do you pitch the wheel pants when you reverse the gear?
Do yourself a favor and pitch the stock gear altogether. When you flip them around they move weight forward and change the CG of a plane that is already nose heavy. I went with the Graphtech gear. They are much lighter and cure the tipping problems. Plus since they are taller they help the plane get off the ground quicker. I am not sure if thewheeel pants will work with them reversed as I never used mine due to being in grass.
