RE: Homelite 25cc conversion
if you are using electronic ignition the whole plate can come off, it doesn't take long with a hack saw, the trick is to make a couple cuts down the side and just break off big pieces with pliers. I wouldn't go all out removing aluminum as all of that on the front is probably 2-3 ounces tops.
