RE: Seagull extra 260 180 gas conversion
Rather than using a tie strap I would get some thin wire and twist it around the tube tightly. I am afraid that with time te tie strap may deteriorate with the gas . I would also solder some solder over the end of the brass lines ,that will make it harder for the tubing to come off. Hope that helps. Doc.....
