RCU Forums - View Single Post - trainer help!
Old 07-05-2009 | 04:26 AM
jetmech05
Default RE: trainer help!
You didn't say anything about the transmitter...is it new as well? perhaps there is some kind of mix in it...
have you ever done a range check with the motor running to see if you get an elevator deflection after the ailerons?
lastly make sure your not adding throttle in your turns as a flat bottomed wing will want to climb with power on.....
