RE: Dual Servo Delta Setup on 12X?
Hi KC36330,
I cant get the AILE or ELEV to 'un-grey' unless I select wing type normal, I have all functions in 17 set to INH.
Are you sure your radio has the AILE and ELEV enabled in the Dual section with a delta wing selected? If so could you go to a new model reset it, make it aero, INH all in 17 and try to set DELTA with Dual?
Sean
