Dual Servo Delta Setup on 12X?
Hi,
Just getting to grips with my new 12X and wondered if I am doing something wrong or perhaps this new set does not support what I am trying to do with an inbuilt mix.
Basically I want a delta wing with dual servos, the manual says that dual servos are available, but when I select wing type delta it will only let me select RUD or FLAP, AILE and ELEV are greyed out??? If I select a nother wing type they are un-greyed, am I missing something obvious?
Sean
Sean
My Feedback: (40)
ORIGINAL: uk-heliman
Hi,
Sean
Hi,
Sean
You are not missing anything obvious because the 12X (surprisingly) does not support dual servos in the Delta wing type. I went through this process a few months back with the assistance of a JR rep. We eventually came up with 4 program mixes in conjunction with Delta wing type to accomplish the task. Here's how:
Select DELTA wing type. Plug the left wing servos into Ail and Aux 4 and the right wing servos into Elev and Aux 2. Program the following mixes:
Ail+ to Aux 2 pos 0 L +100 R +100
Ail+ to Aux 4 pos 0 L +100 R +100
Elev+ to Aux 2 pos 0 D -100 U -100
Elve+ to Aux 4 pos 0 D +100 U +100
You will have to experiment with the throw directions depending upon the direction your servos are installed. The "+" behind the master channels means that they will trim the slave channel but each servo can be sub-trimmed independently to get them matched up.
Of course you could also just use two matchboxes!
Hope this helps.
Craig
my 12x (which is MV version does support it under delta) ............. after you select Delta just wheel over and select DUAL. make sure you have deactivated the other channels under code 17 to get this option....
then the 12x will do all the functions of a matchbox all by it's self so you don't need matchboxes or programable mixing. it's one of the best features of the 12x.
Thanks Craig,
I ended up doing just that, but I cant believe the radio can't do it as a built in mix.
Regards
Sean
Regards
Sean
Hi KC36330,
I cant get the AILE or ELEV to 'un-grey' unless I select wing type normal, I have all functions in 17 set to INH.
Are you sure your radio has the AILE and ELEV enabled in the Dual section with a delta wing selected? If so could you go to a new model reset it, make it aero, INH all in 17 and try to set DELTA with Dual?
Sean
Sean
mine does, but i have the MV version which has some differences in the software over the dedicated version. you have a few features i wish mine had and i have no idea why they didn't put the same software in both.
My Feedback: (40)
ORIGINAL: KC36330
it's very odd, even under the programmable alarms, on the dedicated version you can set an alarm for Aux2 switch being in the UP position, on my MV you can not and on one of my jets I'd prefer Aux2 be in the down position during initialization, i can get an alarm for Middle and Down but not Up
ORIGINAL: CraigG
Ah, that explains the ''MV''. Odd that it would have different programing.
ORIGINAL: KC36330
it's the module version that flies both 2.4 and 72 MHz.
I agree. Two sets of programs/two manuals and a nightmare to support remembering what radio has what functions compaired to the other! I can't understand why JR would do that!
Looks like I will have to stay with my p-mixes then!
Sean
This probably not due to a difference in the models but whether the transmitter has the original or upgraded programing. I have one of the first 12X MV. I cannot get dual servos on the elevator and ailerons with the delta wing. I can get the alarm for the AUX2U position. Also I don't have programable momentary switches nor does the balance work properly for the 4-aileron wing.
Allan
Allan
Hi Allan,
Does your MV have these modified features: [link=http://www.horizonhobby.com/ProdInfo/Files/JR_12X_Manual_Addendum.pdf]12X Manual Addendum[/link]
Sean
Sean
Hi Allan,
Sean
Hi Allan,
Sean
i also have one of the first ones
we also do not have these functions , can they be upgraded?
we need to send our units in? or can we just like futaba users finnaly use our datacables for upgrading our systems?
ORIGINAL: digitech
.......... can they be upgraded?
they can be upgraded but it can not be done by the user.
Assuming this is a software version difference:
1) How do you identify what version of Software your 12X has?
2) Was the DELTA dualing removed from the later software delibritaly or by mistake?
Sean
Sean
i was told that the only differences in the firmware (not software) update was the momentary switching of the eyebrows. my first MV didn't have the latest update so they overnighted me a new TX with the updated software and a recall tag for the other one being I'm their #1 customer
Hi Allan,
Sean
Hi Allan,
Sean
Allan
