RE: Ultra Stick 40 Question
Hi
Most Stik Type planes run with the engine upright for ease of use and operation. You can side mount the engine if you want. just measure for the thrust line, then drill and remount for the side ways engine mount. Obviously you have to modify your throttle linkage to make it work, which is not that hard. You will also need to laterally balance your model to get the wings level.
Vince
