 Ultra Stick 40 Question >
Old 07-05-2009 | 08:56 PM
sierracharlie's Avatar
My Feedback: (21)
Default Ultra Stick 40 Question
What is the significance of side mounting the engine? I will be using an OS 52 and nothing matches from the mount to the pushrod routing.
Old 07-05-2009 | 09:18 PM
vpresley's Avatar
My Feedback: (162)
Default RE: Ultra Stick 40 Question
Hi
Most Stik Type planes run with the engine upright for ease of use and operation. You can side mount the engine if you want. just measure for the thrust line, then drill and remount for the side ways engine mount. Obviously you have to modify your throttle linkage to make it work, which is not that hard. You will also need to laterally balance your model to get the wings level.
Vince
Old 07-05-2009 | 09:40 PM
My Feedback: (21)
Hanger 9 shows the engine side mounted and I am not sure why. It is the side mount that does not match my OS setup.
Old 07-05-2009 | 09:50 PM
rc airplane nut's Avatar
Ill try a link.[link=http://www.rcuniverse.com/forum/m_8854182 /tm.htm]posts #3 and #5[/link]
