RCU Forums - View Single Post - RAM 500 problem. Help please
Old 03-28-2002 | 12:13 AM
sirrom
Default RAM 500 Problem
Jason,
Your EGT Probe may be malfunctioning. Or you maybe getting interference on the ECU itself from your Transmitter. Where is your receiver antennae? Is it close to the ECU/or the EGT probe? If so try moving them. If not then I would call ram and see what they say. The motor is a gem and is a delight to run once setup correctly.
Patrick.
