RCU Forums - View Single Post - TIP / TRICK Using EV5U-PRO Valve with 12X
Old 07-07-2009 | 10:18 AM
Square Nozzle
Default RE: TIP / TRICK Using EV5U-PRO Valve with 12X
Now if someone can convert that into operation on the 9303 I'll be happy. Right now I use the full brake option simply because I also found that the air supply was limited with the anti lock even with my large air tank.
