RE: Aquacraft Mini Rio
I have a wierd question I hope someone can help me out with. I recently ordered an aluminum single rudder conversion set up off ebay that a guy on here recommended. Looks like it will be fairly easy to install. I will have to plug the old holes from the dual rudders, drill to holes and install the rudder and mounting bracket supplied with the bolts and locking nuts it came with. Only problem is connecting my servo linkage. The aluminum rudder uses a tiny hole with a set screw in the top to tighten the rod that goes through it. The stock servo rod is to big in diameter and not long enough. Does someone know what I can use? I think I just need some thinner wire that I can bend my self but I dont know what kind to buy so that it will be stiff and give under load. Thanks for the help...
