ORIGINAL: MadMan_swe
Here we go again...
Checked the engine for air leaks and found none.
Started the engine and I still only got 4900 rpm.
Moved the ignition sensor to 26° but still only 4900 rpm.
Any ideas? Could the ignition still be faulty?
Maybe I should just take this czech piece of crap and use it as an anchor for my boat and get myself a chinese 100cc engine instead...
//Johan
Looks like your ignition is locked in low voltage mode, and does not advance anymore. In order to test this, you have to turn the sensor about 22 degrees clockwise. Because now the ignition is fully advanced, the engine may kick back if you are careless.
If this fails, you can fit an RCexcl ignition as an alternative.
Many folks will gladly accept your "boat anchor" and make it run like it should. Just push the right buttons and that "Czech piece of crap" kicks butt.
