RCU Forums - View Single Post - Engine troubles
Old 07-08-2009 | 03:03 PM
K_B's Avatar
K_B
Default RE: Engine troubles
Did you open the carb up using the idle stop screw or by increasing the throttle trim on radio? If you bumped up the throttle trim, then it stalls because the idle stop screw isn't keeping the carb open far enough when you hit the brakes. Otherwise, you've probably got a clutch shoe hanging up and not disengaging the clutchbell which in turn causes it to stall.
