RCU Forums - View Single Post - MVVS 58cc problem
Old 07-09-2009 | 08:06 AM
MadMan_swe's Avatar
MadMan_swe
Default RE: MVVS 58cc problem
ORIGINAL: pe reivers
Did you just turn the sensor, or moved the sensor + bracket to 22 degrees more advanced firing position?
I fixed the sensor to a hose clamp and moved it somewhere around 22 degrees. As I suspected ( and like you said ) the engine kicked back so there´s no doubt that the ignition was advanced, but still it just doesn´t wanna go past 4900rpm...
