RE: ASP 21 GOING CRAZY trying to find the propnut size and thread count??? HELP
Do you have a set of calipers or a micrometer? Once you establish the thread OD, ( it will be a little undersized from the nominal size), the the thread cound is a given.
The Magunum line, same as the ASP, brackets your engine. The 28 uses a 1/4-28 thread and the 15 uses a 6MM thread. It has to be one of the two.
Don
