RCU Forums - View Single Post - Beginner??? Probably!
Old 07-10-2009 | 08:42 AM
  #113
Kennelmaster
Default RE: Beginner??? Probably!
AndyW;
Your advice is different from my first flight plans and I would like you to explain why you choose to do lazy ovals with the ailerons rather than the rudder.
Here are my thoughts.  With the A/C at altitude, and slow, skid the a/c around the oval with a little rudder.  gets both thumbs working.  I expect a little nose drop with the rudder, perhaps more so than with ailerons.  Rudder would be my choice for landing approach so why not use it to start rather than ailerons.  I can work in coordinated turns with ailerons later in flights.
That's my thought process.  I would like to hear your thoughts because (and don't tell my wife) I could be wrong here.</p>
</p>
Thanks</p>
Paul</p>
