RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 07-10-2009 | 09:39 PM
  #996
RICKSTUBBZ's Avatar
RICKSTUBBZ
Default RE: Phoenix Extra 330S 60-90 Size
In order to keep things in chronological order, here is some baffle work I did on my extra Wednesday and Thursday.
With trial and error fitting I made a paper template to fit in the cowl just in front of the fins on engine cylinder. Once I was happy with the fit I cut it out of 1/32 balsa. I used some pieces of the same to create doublers around the edges. A couple curved pieces across the middle and a couple of air damns running down the sides of the cylinder. Sealed with 5 minute epoxy and painted with Top Flight Luster Coat. Weighed in just over a half ounce.
ID:	1233548   Click image for larger version
ID:	1233549   Click image for larger version
ID:	1233550   Click image for larger version
ID:	1233551   Click image for larger version
ID:	1233552   Click image for larger version
ID:	1233553   Click image for larger version
ID:	1233554   Click image for larger version
