RCU Forums - View Single Post - t-34 build
Thread: t-34 build
Old 07-10-2009 | 10:37 PM
All Tanked Up's Avatar
All Tanked Up
Default RE: t-34 build
Here is a build one of my members did for me. I've ran it several times at the AAF museum's battlefield. It seems to be holding up pretty good. The gears are the metal replacement ones. The suspension arms are Daryl Turner's machined aluminum ones that he makes and sells. And yes, you really need to beef up the chassis as it has lots of flex to it. I have also had Daryl install an aluminum drive sprocket and steel shaft with ball bearings on the idler as I have snapped two of them off by just running into something. Both of which he makes and sells as well.
ID:	1233628   Click image for larger version
ID:	1233629   Click image for larger version
ID:	1233630   Click image for larger version
