RCU Forums - View Single Post - Evolution 26 getting Hot
Old 07-11-2009 | 06:16 AM
pe reivers
Default RE: Evolution 26 getting Hot
The carb getting hot, with all else the same as before indicates crankshaft rubbing in the front bushing. This can be due to lack of cooling, or crankshaft/bearing combo out of whack. Did you get a prop strike? I suspect either a bent shaft or worn front bearing.
BTW proper plug gap is 0.020 - 0.024 " Too small a gap may also cause hot running.
