RCU Forums - View Single Post - 16' Rigger
Thread: 16' Rigger
Old 07-11-2009 | 03:39 PM
christo stemmet
Default 16' Rigger
Hi guys! Im busy building a 16' predator rigger. This is my first rigger and I still know very little about this. I was thinking of using this outrunner motor. Do you guys think it will do? Im a south african scholar and im building this as a expo project so I need it to be fast. I was also wondering what the overall weight in grams (g) should be for a 16' rigger after it is fully completed.. The build is comming along very nicely and I will soon post pics. Thanks very much.<table cellspacing="3" cellpadding="1" bordercolor="#0062c4" border="0" bgcolor="#d5daff" width="800"> <tbody> <tr> <td bgcolor="#ffe1ff" valign="top"> <div align="center">High Quality</div> </td> </tr> <tr> <td bgcolor="#ffe1ff" width="391" valign="top"> <div align="center"></div> </td> <td bgcolor="#ffe1ff" width="610" valign="top"></td> </tr> <tr> <td bgcolor="#239ac7" valign="top"></td> <td bgcolor="#239ac7" valign="top"><span class="Style2"><span class="Style1"> SPECIFICATIONS</span></span></td> </tr> <tr> <td bgcolor="#ffffff" valign="top"></td> <td bgcolor="#ffffff" valign="top"> <p class="Style12">Brushless Motor KDS WS2217 3800kv for 450 size helis</p> <p class="Style12">High Quality product.</p>
KDS-WS2217 BL motor developed by the latest technologies by KDS is designed for 450 EP helicopter specially. The KDS-WS2217 utilizes unrivaled Ndfeb extra strong magnets and a low friction, double ZZ high efficiency bearing. The KDS-WS2217 will be the most revolutionary motor operating on low current amperage, and delivering high torque to RC models.</p> <p class="Style12">FOR:</p> <ul>[*]T-REX 450[*]KDS 450[*]CopterX[*]Similar[/list]
The KDS-WS2217 is maintenance free, and has a light, compact design. The motor operates with very high efficiency, and low consumption. It can provide many hours of smooth, reliable, quiet, and efficient flight.</p>
High KV value and high torque design.</p>
The KDS-WS2217 utilizes big diameter bearing. It is steady reliable and can work for long. The KDS-WS2217 is designed with new radiator System which can lower temperature for working motor.</p>
The KDS-WS2217 is a new type motor, which developed and cornpleted by various of thorough examinations and tests by technical department in our company.</p>
The tests contain many items,included as dynamic test, static test, magnetic field test, heat resistance, magnet damage test, operation balance, vibration test and noise test.</p> <p class="Style12">SPECIFICATIONS</p> <ul>[*]Length: 36.4mm[*]Diameter: 27.8mm[*]Shaft: 3.175mm[*]Real Measured Weight: 67g[*]Kv: 3800kv[*]Max Current:45A[/list]<p class="Style12">ACCESSORIES</p> <ul>[*]12T Pinion[*]13T Pinion[*]4mm banana connectors x 3[*]Heat Shrink tubes x 3[/list]</td> </tr> </tbody></table>
