RE: 16' Rigger
Hi Christo,
Outrunners don't have much aircooling in a narrow hull like a rigger, though the build in fan will help.
If you have the time and resources, make a watercooled motormount, so you can at least cool away the heat from the stator.
The picture shows a commercial version, but you can make your own out of aluminum strip and drill a hole to fit an aluminum tube, where the water runs through,
Let me know if I should provide a pic of that.
Regards, Jan.
