RE: Idle speed problems
What happens if you idle it down to about 1500? does it shut off? If so try opening the low speed needle or you may have to clode the low speed needle a turn or two. If the low speed needle has no effect on the engine at all then the passage in the carb is blocked. using compressed air you may be able to blow out the blockage. If it won't idle lower then 2500 then you have a air leak.
