ORIGINAL: Bad Tooth
Can anyone suggest a good, cheap receiver to use for combat? Is there any problem with using a single channel Rx with a plane like the battle axe?
Hi Bad Tooth,
The Battle Axe will accommodate anything up to a standard 7-channel 72 mHz receiver in size. Years back (circa 2004 I believe) I used Hitec Feather single-conversion receivers in my Battle Axe's, but eventually ran into an interference issue with a certain combination of two other radios. Because single-conversion is inherently more susceptible to interference, I wouldn't recommend using it with any airframe beyond the manufacturer's recommendations.
Have fun and let us know how you do! [8D]
Best regards,
Alex Treneff
