RE: Reassembling Flybar: Paddle Accuracy
The weights can be placed at various lengths down the flybar, the closer they are to the end the easier the cx will fly, once however you get the hang of it you can reduce the weight of them and or shorten flybar to give the cx more manoverability. The only golden rule is keep the weights equal in mass and exactly the same distance down the flybar as each other. Calipers or a simple tape measure can be used.
