RUNNING G2
HAY SCOTT,
DO ONE OF THE FOLLOWING... CHECK WITH GREATPLANES TECH PEOPLE AND HAVE THEM RUN THROUGHT THE INSTALL WITH YOU ON THE PHONE.ONLY BAD THING IS..ITS YOUR DIME.IF YOU HAVE THE G2 UP GRADE DISC FOR YOUR RF DELUXE, YOU CAN CHECK WITH THE TECH PEOPLE TO SEE IF THEY WILL LET YOU SEND YOUR RF DELUXE & G2 UP GRADE DISC IN FOR A NEWER VERSION OF G2 FULL VERSION AT NO COST OTHER THEN S&H. I DID IT ABOUT THREE WEEKS AGO AND TURN AROUND TIME IS LESS THEN TEN DAYS.OOOORRRRRR YOU CAN CHECK WITH AMCROSS AND SEE WHAT SHE THINKS... THAT FREE AT NO CHARGE. HOPE TO SEE YOU ON THE NET WHEN I HOST A FUN FLY AGAIN.GOOD LUCK.
NEDYOB
