run G2 and addons from HD? (copy CD to HD?)
My Feedback: (17)
Has anybody copied any or all the CD's to the hard drive to speed boot up time? I'm running G2 with Addons 1 and 2, and it also requries the RF Deluxe CD...
are there any tips/tricks in doing this? might I have to reinstall since it looks at the CD drive for the files, or it might be in some config file?
Thanks much in advance,
Scott
Scott
My Feedback: (67)
IA
HAY SCOTT,
DO ONE OF THE FOLLOWING... CHECK WITH GREATPLANES TECH PEOPLE AND HAVE THEM RUN THROUGHT THE INSTALL WITH YOU ON THE PHONE.ONLY BAD THING IS..ITS YOUR DIME.IF YOU HAVE THE G2 UP GRADE DISC FOR YOUR RF DELUXE, YOU CAN CHECK WITH THE TECH PEOPLE TO SEE IF THEY WILL LET YOU SEND YOUR RF DELUXE & G2 UP GRADE DISC IN FOR A NEWER VERSION OF G2 FULL VERSION AT NO COST OTHER THEN S&H. I DID IT ABOUT THREE WEEKS AGO AND TURN AROUND TIME IS LESS THEN TEN DAYS.OOOORRRRRR YOU CAN CHECK WITH AMCROSS AND SEE WHAT SHE THINKS... THAT FREE AT NO CHARGE. HOPE TO SEE YOU ON THE NET WHEN I HOST A FUN FLY AGAIN.GOOD LUCK.
NEDYOB
NEDYOB
IL
Scott,
You can't run without the CDs. You MUST have the disk in place for the software to run. Howeve,r the most recent update of G2 does a lot to help minimize the 'disk swapping'.
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Services and Support
Great Planes Model Distributors
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
MI
I have a program called Virtual CD that will allow you to run a program dependant upon the CD to run from the hard drive. I still have the lowly R/C Pilot which is CD dependant and it loads much quicker than running from the CD. Be aware that you must have a large amount of memory. I also am running Simon and Schuster Dictionary and Thesaurus and Microsoft Golf 99. It can be done but it's not for the inexperienced computer user.
