RE: Idle speed problems
Start it up and spray carb cleaner at the seals at idle, if the rpm changes you have a leaking seal, if not then look elsewhere.
Put the stock ignition back on and see if that solves the problem.I don't trust aftermarket ignitions on zenoahs.
