RE: Change spring in spark plug cap
The Vlach ignitions that have the shielded plug boot and contact spring are not made anymore because the producer ended his business.
You can fit a snipped ball point pen spring inside the cast part. That will work well. There need not be more than slight contact with the flat plug top.
Leave the remainder of the old spring in place.
