MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Change spring in spark plug cap
Old 07-14-2009 | 06:25 AM
Default Change spring in spark plug cap
On my MVVS 116 twin, the spring in the spark plug cap - on one side, is broken in half. This makes a sloppy contact with the top of the plug. How can I change the spring with a new one?
mvh.: Jan Eirik Olufsen - Oslo - Norway
Old 07-14-2009 | 06:29 AM
Default RE: Change spring in spark plug cap
I forgot to mention - the ignition is of the "old" type - up to 6 Volt style.
mvh.: Jan Eirik.
Old 07-14-2009 | 06:40 AM
The Vlach ignitions that have the shielded plug boot and contact spring are not made anymore because the producer ended his business.
You can fit a snipped ball point pen spring inside the cast part. That will work well. There need not be more than slight contact with the flat plug top.
Leave the remainder of the old spring in place.
