RE: Getting some sort of glitching / Interference.
Well that SUCKS, Kenny! I'd thought for sure that the ferrite ring would cure your servo-woes / interference issues.[:'(] I wonder if it could be the BL motor, have you tried removing the motor from the ESC (pull 2 of the BL wires off, motor won't run on 1 phase). Does it still twitch? If you change throttle position does that change anything?
Shadow
