RE: Idle Problem
I experience the same problem with my A51 .adjusting the needles did not help .Hot engines create vacuum leaks because metal expands, do a smoke test . Have a smoker blow smoke through the pulse port with the piston closing the exhaust port & note were it comes out then fix the leak mine had a major leak from the front bearings. Good luck.
