RE: 10c programming help please
Hi Andrew,
You could do two offset mixes, one with each of the aileron servos as slave, and set this to the H switch at a specific rate that you choose say 50%. But if you are using the VRE at anything other than absolute center, this will cause the servos to deflect more than the 50% rate you set on switch H.
Let me work with this a little and see what I can come up with.
Krysta
