Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
10c programming help please
Old 07-15-2009 | 09:02 AM
diviatix's Avatar
Default 10c programming help please
Hi Bax and Krysta.
I currently use a 10c with a flap function (both ailerons actually) connected to VRE (the right index slider). This allows me to use the slider one way for flaps and the other way for spoilers.
I would like to assign SWH (trainer switch) to a spoiler function. So when the switch is held up both ailerons flip up a predetermined amount. (ailerons are on 2 channels)
If it's an either or situation, I wouldn't mind losing the VRE function in favor of the spoiler function I'm inquiring about.
Can you please give me some advice on how to go about setting this up?
Regards,
Andrew.
PS: Still absolutely love my 10c - and I've never had 1 twitch or glitch from my original 14ch receiver either.
Old 07-15-2009 | 01:09 PM
Default RE: 10c programming help please
Hi Andrew,
You could do two offset mixes, one with each of the aileron servos as slave, and set this to the H switch at a specific rate that you choose say 50%. But if you are using the VRE at anything other than absolute center, this will cause the servos to deflect more than the 50% rate you set on switch H.
Let me work with this a little and see what I can come up with.
Krysta
