RE: New Engine Pre-install prep
Make Sure to use the Collet that Came with the Flywheel & Not the One on the New Engine..........(The LST's Collet is Shorter than Most others) And the Engines are the Same....The Teal head has a Bigger Carb and High Compression Head Button...But other than that they are 100% the Same Engine & both made by SH Engines/Golden lion......
