RCU Forums - View Single Post - Upgrading to T-Rex 450SA
Old 07-16-2009 | 08:17 PM
ace22459
Default RE: Upgrading to T-Rex 450SA
What motor comes with the Blade? Is it a E-Flight 420? If so, it has a 2.3mm shaft. I checked and the Blade uses a .5 module pitch pinion so you can order an 11 tooth for the Blade 400 from ReadyHeli and it will work with the EXI. If you want a 12 or 13 tooth you'll have to look around a little. Alan
