RCU Forums - View Single Post - throttle push rod set up
Old 07-17-2009 | 07:53 PM
hauckf
Default RE: throttle push rod set up
If the throttle arm on the carb is metal, do not use a metal clevis. Metal-to-metal contact could cause radio interference. I would suggest a ball link on the throttle arm. As for the push rod, what you have would probably work OK.
