RCU Forums - View Single Post - throttle push rod set up
Old 07-17-2009 | 09:43 PM
Tired Old Man
Default RE: throttle push rod set up
Some pics. We will not go into the debate about how carbon rods might generate rfi. Take a real close look at the installation before you go in that direction. All my planes use similar installations, all using 72mhz radios. If you use a product that can flex, it eventually will, at the worst possible time.
ID:	1238553   Click image for larger version
ID:	1238554   Click image for larger version
