how to connect elevator in an edge 60...
Hello guys,
I have an edge 60 that uses 2 servos for the elevator installed one at each side of the tail (one per half elevator)... I have a DX7 and a 5ch Rx, I really do not want to buy a 6CH for this one. I have a problem, I guess it is a dummy question for many of you but personally I have no idea how to solve it. I used a Y extension to plug both elevators to the ELEVATOR CHANNEL and well, they go in opposite directions.... I really do not want to get into mixing because the only channel I have free is the GEAR channel which is a pain in the ass because it is used normally for flaps (not in this case) but it is enable by default with the GEAR switch....
How can I set up my elevator using just 1 channel????
Thanks....
