JR 9303 Smoke system help.
ok, i just installed a smoke pump in my extra. I ran into a wall when it came to programming it. I have the pump in the aux 3 slot and have it set to work with the throttle as master and aux3 as slave. I want to use the mix switch. The mixing seems to work fine. The pump runs with the throttle very well. My problem is, i cant get it to shut off. With the switch in one position, the pump works exactly how i want it to, but when i switch the switch, it just make the pump run about 80%, not shut off.
Ive tried reversing the switch, and ive tried changing all the output values to 0 or -100. Still wont shut off. Im using the gear switch as my ignition kill, so i dont want to move that.
Any ideas?
