RCU Forums - View Single Post - throttle push rod set up
Old 07-18-2009 | 01:46 PM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: throttle push rod set up
If you're talking a rigid push rod, run CF tubing over the threaded rod just like TOM does in his pic. If you need to run it a distance without a clean shot between the servo and carb then run the flex rod in the sheath. I use the stuff w8ye showed in post #2. I love the stuff. Works great.
