RCU Forums - View Single Post - Webra 12 Pattern Project
Old 07-19-2009 | 09:35 AM
ccp10
Default RE: Webra 12 Pattern Project
David,
In post #10 you list as attachments, the full size plan and from what I gather is a 61% tiled plan. Is this correct? I downloaded and printed out the tiled version. This is what I used to start my build with. You mention here and in the Pico thread a 40 inch version. This tiled version only has a 38" span. Did I miss something?
Anyway as you can see from the picture It's comming along. I think it's way to small for the Magnum 15XL and Macs pipe I planed on though. Auw is 19.5 oz as you see it in the pic. this is with a built up wing. I expect this is as far as i'll take this one, cause I think it needs to be a little larger.
Good luck with the Pico!
chuck
