RE: new Arf Boomerang 14lb thrust
Shaker, it does exactly the same thing with the hatch open, so while I do agree that a Wren SS does need larger intakes it is not my main problem.
Turbinac, thanks for the parameters, you are all lucky to have acceleration delay 15, at this srtting it should spool up super fast ! your deceleration delay is also very low, what advantage does it provide ? do you think I can also lower mine the same way ?
