RCU Forums - View Single Post - Stickit IV mods?
Old 04-01-2002 | 11:28 AM
Azarr
Default Re: S I airfoil mod and mount
Originally posted by miderror
Its been awhile so the pic below isn't too scale but the airfoil
mod cut is there. Might let Assar verify but this is how I remeber
the mod.
On the motor mount you can just order up the 1/4" end grain
carbon lam. like is listed at this site http://cstsales.com/carbon-panels.htm
good luck
Yes, this is the correct mod and should be done both top and bottom; basically moves the high point of the airfoil forward. The Tapered ailerons on the Stickit IV were a concession to the masses for kitting purposes, they just flat looked better. For performance, the ailerons should be rectangular for more aileron area. Tapering in the tips as suggested stops a lot of gear breakage.
