RE: Upgrading to T-Rex 450SA
blades not tracking? sometimes if i swap my blades on the grips it tracks.
bad dampers, loose ball links, bent head block, bent mixing arm screws, bad bearings...just some of the things to check.and of course the usual suspect like the feathering shaft and the main shaft.
i measure my linkages with a digital caliper so i can get the them as close as possible.
Cool. i have the dx6i also.
