RE: Problem with Outrigger?
I have run several riggers in the past. Some of which had rear ride pads and some that have not. Larger hulls you typically can not get away without using them. Smaller hulls without a rear ride pad will allow a prop with greater pitch and lift resulting in increased top speeds with reduced drag. Many cases it's a personal preference.
Ryan
