RCU Forums - View Single Post - Nemesis Hitec 5955 problem
Old 07-21-2009 | 07:52 AM
nomobux's Avatar
nomobux
Default RE: Nemesis Hitec 5955 problem
ORIGINAL: TycoBandit
I have the Airtronics MX-3 75Mhz model/92836 3 CH. Recv. This radio has a bunch of stuff on it but I have no clue as to what any of it means. The instruction manual isn't all that great for a new guy. I'm looking at the manual now and it does have end pt. adjustments.
Ok , MX3 should do the job. Carefully read the directions for the end points on steering. You want to set full left and right one at a time ( be sure the servo is centered 1st ) I go full each way and back off the end point of the servo just a hair. You are just limiting the servo travel so that it isn't fighting the stops. Hard to explain, but look at the steering and you should get the idea. let us know how it goes
