RCU Forums - View Single Post - how to connect elevator in an edge 60...
Old 07-22-2009 | 09:02 AM
matador_24
Default RE: how to connect elevator in an edge 60...
Hello guys,
I finally used the mixing in my transmitter with the AR500, I used the GEAR channel as slave.... However, I can not inhibit the SWITCH and whenever I push it, half of the elevator works as a flap!! that during flight would be a catastrophe!! (in the DX7 you can inhibit the FLAP and AUX1 channel but I do not see the way to inhibit the GEAR channel!!!).... anyways, I flew it like that yesterday and I really liked the plane, it flies very nice..... I had about 6-7 flights... all of them good. I appreciate the help in this forum......
However, I ordered a Y-reversing harness for 9.99 and I should get it next week, I think I'll use that because I do not like the idea that the switch is enabled and I can mistakenly push it during flight and it would be a mess!!!!! also, even though I put GEAR-ELEVATOR with sames travel, same everything... I see the GEAR elevator has a bit more of travel than the ELEVATOR one, hard to tell, some milimetes, however, I am sure, because during flight I could see how the plane would loop but moving slightly to one side.....
Anyways, I guess that the Y-reversing harness would definetely get the same travel for both servos and that problem should be solved!!!!!
