RCU Forums - View Single Post - Sheeting Wings help?
Old 07-23-2009 | 03:39 PM
Tjetfire94
Default Sheeting Wings help?
Hi,
I have had a sig tristar kit for a while and have finally goten to the sheeting phase. I cut all the sheets and preped to glue them on. I was told to use the contact cement. The kit came with foam core wings and the container said it is used for foam. So I proceded to start gluing the sheets on, and brushed some of the contact cement on. As I put more on, I realized that the glue was eating the foam and wondered if it was the kind of foam used, or was it just the glue? The kit is pretty old so I was wondering if it could be old foam that caused the problem? Also would epoxy work on this?
-TJ
