RE: what about Jonsered
As Far as converting engines, you should study your candidate's layout
Carbs above the flywheel are hard to contend with
side crankcase reed valves are awkward
Roller main bearings don't seem to work out as easy as ball mains.
Magnesium crankcases are dangerous to be aggressively cutting on
Look for ease of conversion like can the crankcase be separated from the saw frame and how are you going to mount the crankcase to the plane
is the coil mounted on the engine
is the carb mounted on the engine or the saw frame
Where is the carb and exhaust going to be
What will the likely all up weight be
Do you have a plane for it
